Home Forums Connect Webrings Settings
Community: 28 connected
(IRC: 5 | Mumble: 0 | XMPP: 23)
Finally deleting more online accounts of mine
Sep 9 at 11:05:49 in General Discussion  |  [RSS Feed]
Anonymous - Sep 9 at 11:05:49 #51383
I finally deleted my accounts for sites I don't use anymore like deviantant, inkybunny, e621 etc. Feels good man. Now if only I could delete my twitter accounts too.
Btw deviantart is now 25 years old. what a great timing for deleting my deviantart account, huh?
Anonymous - Sep 9 at 13:15:08 #51386
Good job, OP. Keep a list if you can too. Which ones you think you still need, which ones you don't, which ones you can't delete or contacted support for already. It's worth the extra effort in the long run.
Anonymous - Sep 9 at 13:54:03 #51387
Years ago I started to gradually delete more and more online accounts (mostly social media), stop using more and more sites, spend less and less time on certain sites, spend less and less time on pointless lurkng (or at least I try) etc.
Anonymous - Sep 10 at 13:09:56 #51431
what's stopping you?
Anonymous - Sep 10 at 13:51:08 #51433
I guess because he probably uses Twitter for more than just porn.
Anonymous - Sep 10 at 16:05:51 #51437
I use twitter for art (including porn art) and for looking for info about old Japanese obscure games. Otherwise I would gladly delete my accounts.
Anonymous - Oct 13 at 12:57:49 #52236
your first step should be to stop engaging with all porn immediately it is a waste on your life and only causes problems for you. Getting rid of porn easily creates as positive snowball effect where you'll be able to get rid of your other online addictions quickly and efficiently, and your lifestyle will improve tremendously as a result.
