Home Forums Connect Webrings Settings
Community: 23 connected
(IRC: 8 | Mumble: 0 | XMPP: 15)
How I Almost Killed Cyberix (And What I Learned)
Aug 28 at 01:56:31 in General Discussion  |  [RSS Feed]
admin ## ADMIN - Aug 28 at 01:56:31 #51119
The Setup
Three days ago, Cyberix went completely dark. Not due to a hack, DDoS attack, or hosting provider failure. I killed it myself through a series of increasingly stupid decisions that culminated in accidentally nuking the entire site's data.
This is the story of how overconfidence, cost-cutting, and a fundamental misunderstanding of Podman's container storage nearly destroyed everything we'd built.
The Foreshadowing
It started with a number that bothered me: 100 gigabytes. That's how much storage space the server was using, and I was paying for every byte of it. The rational part of my brain knew that downsizing the disk would require careful planning and proper backups. The impatient part of my brain kept looking at the monthly hosting bill.
Foreshadowing, meet hubris.
The Discovery
A few days later, I noticed something weird. The /srv/ directory - where all the important stuff was supposed to live - was only 12GB. So where were the other 75GB hiding?
The culprit: /var/lib/containers was absolutely stuffed with Docker images, volumes, and what I assumed was just garbage data from old containers. This had to be the problem. Clean this up, problem solved, right?
Wrong.
The First Mistake
My inexperienced self decided that nuking /var/lib/containers through various podman reset commands would clean up all the "dangling" images and volumes. I thought I was just clearing cache and unused data.
The cleanup freed exactly 6 gigabytes. All containers were still running. The mystery 75GB was still there.
What I didn't realize: the bloat wasn't from dangling images. It was from my own terrible Podman practices. I had been building images that included entire game installations (Team Fortress 2, Xonotic, Minecraft, Terraria) and then mounting those same directories as volumes. This created massive data duplication - the same 20GB TF2 installation existed both in the image and as mounted volumes.
Two TF2 servers meant 80GB of redundant game data alone.
The Second Mistake
Still clueless about the real cause, I decided to get aggressive. Turn off all containers, manually delete them, nuke everything container-related, then restart them one by one to identify what was actually consuming space.
This was the point of no return, though I didn't know it yet.
The Revelation
After the nuclear cleanup, something beautiful happened: the server was using less than 10GB of space total.
And then something terrible occurred to me: if the server only needs 10GB, why am I paying for 100GB of SSD space? I could downsize the disk and save money! No more wasting donations on unused storage for game servers that nobody plays on anyway.
This seemed like genius-level optimization.
The Point of No Return
I contacted my hosting provider to downsize the SSD. They informed me that resizing requires completely deleting the current disk and reinstalling everything from scratch.
"Do you have backups?" they asked.
"Of course," I replied confidently. "I just need to backup the 12GB /srv/ folder where everything important lives."
This was mistake number three: assuming I understood where all the critical data was stored.
The Catastrophe
Disk deleted. Alpine Linux reinstalled. Time to restore the website from the /srv/web backup.
That's when I discovered that the MySQL database - containing all articles, forum posts, user accounts, everything - wasn't in /srv/. It was living happily in /var/lib/containers until I murdered it.
Three articles that had generated genuine discussion and controversy across multiple communities: gone. Forum posts: gone. User registrations: gone. Comment threads: gone.
The site was now a beautiful, empty shell running on a cost-optimized 10GB SSD.
The Silver Lining
At least I was now paying only €8.70 per month instead of whatever the 100GB plan cost. The site's financial runway just got significantly longer, assuming there was still a site worth running.
The Recovery
Panic-driven restoration began. I transferred the surviving services: IRC, XMPP, Mumble, and the bridge between them. These had been properly configured to store data in /srv/ from the beginning, so they survived the apocalypse intact.
More importantly, I completely rewrote the container configurations to ensure everything saves in /srv/ and nowhere else. No more mystery data locations. No more trusting that containers will behave predictably:
volumes:
  - ./mysql/data:/var/lib/mysql  # Bind mount to host for /var/lib immunity
Every critical service now explicitly binds its data to the host filesystem in a location I control and understand.
The Miracle
I found salvation on my laptop: a MySQL backup from exactly three days before the site had gone down. I had created it during the last round of site updates but completely forgotten about it.
We lost everything posted after those three articles, but the articles themselves and the original forum structure were recoverable. The community discussions, reactions, and new user registrations from the past few days: still gone.
What I Learned
Container storage is not intuitive. Just because you mount a volume doesn't mean that's where all the data lives. Database containers, especially, love to hide critical files in unexpected places.
"Cleanup" operations are never as safe as they seem. When you don't fully understand what you're cleaning, you're not cleaning, rather you're playing Russian roulette with your data.
Proper backups require understanding your entire data footprint. You can't back up what you don't know exists.
Cost optimization should never come before data security. The €20/month I was trying to save nearly cost me months of work and community building.
Documentation beats assumptions every time. If I had properly documented where each service stored its data, this disaster wouldn't have happened.
The Technical Fix
The new container architecture follows a simple rule: if it's important, it lives in /srv/ and gets backed up. Period.
Database files, configuration files, user uploads, logs - everything is explicitly mapped to known locations on the host filesystem. No more mystery storage in /var/lib/containers/ where one wrong command can wipe out everything.
The Human Cost
The technical recovery was straightforward once I understood the problem. The real cost was community momentum. People who had engaged with the articles, left thoughtful comments, or registered accounts had their contributions vanish.
Some will come back. Others won't bother. That's the price of learning system administration in production.
Moving Forward
Cyberix is back online with a leaner, more robust architecture. The hosting costs are now sustainable long-term, and the data storage practices are actually comprehensible.
Most importantly, I now have automated daily backups of the entire /srv/ directory, plus manual snapshots before any major system changes.
The site lost some momentum, but it gained something valuable: a administrator who finally understands the systems he's running.
The Real Lesson
Running independent web services requires more than just ideological opposition to corporate platforms. It requires actual competence in system administration, backup strategies, and understanding the tools you're using.
I got lucky. The backup existed, the community survived, and the financial damage was minimal. Next time, I might not be so fortunate.
If you're running your own services, learn from my mistakes:
  • Document where everything stores its data
  • Test your backups before you need them
  • Understand your containers before you delete them
  • Never optimize costs by destroying things you don't understand
The internet culture of old was built by people who understood their systems. If we want to recreate that independence, we need to develop that same technical competence, after all.
Otherwise, we're just LARPing as sysadmins until the next catastrophic learning experience.
Cyberix Network is back online at cy-x.net. All services restored, backups automated, hubris temporarily contained.
Cr0s5H34D_QA ## GOLD - Aug 28 at 16:15:36 #51125
that's crazy.. anyway...
Anonymous - Aug 28 at 17:17:47 #51126
Welcome back. I wouldn't worry too much about the site losing momentum, due to the fact that you kept us updated on what was going on and told us you were working on fixing the issue. A blank 404 page might have made people think the site was really gone for good.
Foxdie - Aug 29 at 08:11:19 #51170
Been there before. After almost 10 years of linux systems administration, one jumps hops and fences only to fall flat on your face. But it is a learning process and I am glad you went through this and came back better prepared! Thanks for keeping this up.
Anonymous [Tor] [VPN] [DATACENTER] - Aug 31 at 06:26:18 #51213
I knew docker was better.
docman [Tor] - Sep 24 at 17:57:39 #51699
why are you using podman instead of just docker?
Anonymous - Oct 18 at 23:46:28 #52342
(I am going to leave out some details)
I remember I had my own catastrophe but on a much smaller scale, I had an images folder filled with all the images I gathered and collected from talking to people on Discord (it was filled with jokes and funny moments I had with my friends, good times)
I moved it to the external hard drive because my brother needed to free up space on our laptop even though the folder didn't take that much anyways
A long time after that one of my friends had a problem with me at the time because I downloaded some stuff he shared with us on discord and he didn't like it (like personal stuff like selfies but he's always wearing a balaclava and I only downloaded them to use them to make memes and jokes)
I was pissed at the time and told myself (Fuck it! Delete the whole folder)
And I did only to realize to my horror that I did not infact have another backup of the folder on my laptop and that I had deleted a folder filled with good memories and conversations with my friends
Moral of the story
Check before you your delete backups, that backup might be the actual folder and not a backup version you had
