schools can't possibly cope with AI around
Sep 4 at 01:30:02 in General Discussion | [RSS Feed]
>go back to school for shits and giggles mostly cause my job is paying for it
You're literally atrophying your already lazy brain and think you're smarter than your professor. This will bite you in the ass one day and you'll deserve it.
His professor IS a retard though
Then what does that say about OP?
MIT Study Finds Artificial Intelligence Use Reprograms the Brain, Leading to Cognitive Decline >A new MIT study titled, Your Brain on ChatGPT: Accumulation of Cognitive Debt when Using an AI Assistant for Essay Writing Task, has found that using ChatGPT to help write essays leads to long-term cognitive harm—measurable through EEG brain scans. Students who repeatedly relied on ChatGPT showed weakened neural connectivity, impaired memory recall, and diminished sense of ownership over their own writing. While the AI-generated content often scored well, the brains behind it were shutting down.
>>A new MIT study titled, Your Brain on ChatGPT: Accumulation of Cognitive Debt when Using an AI Assistant for Essay Writing Task, has found that using ChatGPT to help write essays leads to long-term cognitive harm—measurable through EEG brain scans. Students who repeatedly relied on ChatGPT showed weakened neural connectivity, impaired memory recall, and diminished sense of ownership over their own writing. While the AI-generated content often scored well, the brains behind it were shutting down. OPs reason for using AI was justified. As long as you don't let it take control, you're fine.
>MIT Study Finds Artificial Intelligence Use Reprograms the Brain, Leading to Cognitive Decline Why the fuck should I have to put up with shitty, irresponsible teachers and retarded children whose parents can't get ahold of them (at least where I live) when I can use AI and it'll immediately give me a proper rundown on the subject I am interested in? While yes, it should not be trusted for medium+ sized coding projects or history/ideology, it's a good tool at best.
The last 2 posts prove that the study is right.
I can tell you why he's so grumpy about it. Because he has to sit down and mark assignment after assignment of generated junk. It'd make anyone go crazy. I'd rather read an awful but honest attempt at work, at least it's not boring. "Learn to actually teach"... words I've often heard from my peers in my last three years at university. I've accepted that bad teachers are simply the rule, and that it doesn't get better. My experiences have only become more absurd, more strict, more hellish. Every semester I have to send multiple e-mails to assessors who screwed up my marking and 90% of the time I am correct, they admit they screwed up. I hate having to do that. You'd be fired from a lesser paid job if you made mistakes at even a quarter the rate a university assessor does. Out of curiosity, what are you studying? Something computer or engineering probably? I don't know any other degree that gets sponsored.
The sheer audacity to constantly fill online places with continuous whining never fails to amaze me. Clearly, if LLMs haven't cooked your brain cells, at least attempt to find solutions. So, at the very least, no one would point out your pretentious hypocrisy. Tools can yield results that are either beneficial or harmful, depending on the person using them. These instruments cannot rob anyone of something they don't possess initially.
>when I can use AI and it'll immediately give me a proper rundown on the subject I am interested in? That's the issue, I don't know how you've never ran into any situation with an LLM where it just hallucinated something that was wholly inaccurate or completely fabricated. You're using it in precisely the most dangerous and ridiculous way, because it will very confidently spew absolute bullshit at you and if you're learning the subject then you will have no way of verifying the output of the LLM. If you want to use LLMs to generate some boilerplate code or otherwise just save you the effort of typing something that is already within your abilities but is truly just a waste of time (like writing a "unique" cover letter for each of the 20 jobs you might be applying to) then go ahead. But if you're using it to study you're just fooling yourself, you already said you're employed so there's not a massive amount of pressure to finish this degree or get perfect grades, so go find a book or alternative lectures on the subject online, take some stimulants of your choice, and study in the same exact way people did a decade ago.
>if you're using it to study you're just fooling yourself I usually use give it the material to make anki cards out of. This saves a lot of time writing my own cards or studying directly from the material. That's just my personal way of doing things though.
AI is kind of incapable of doing geometry
>the hallucinations are painfully obvious most of the time I'm sorry, but do you realize how insane this sounds? You have no idea if it's hallucinating or not, you're just going based off of vibes on a subject you're not well-versed in, in a situation where there is absolutely reason to assume that risk. Studying is inherently an inefficient process, and is intentionally so because we are inefficient beings and the repetition is needed to solidify concepts in our heads. If you wanted to "solve" studying a decade ago you could have just refused to learn the subject and decided that it was ok with you if the subject could only be recalled by consulting the pre-existing literature.
AI will replace teachers. When it comes to explaining school stuff AI is magnitudes better than the average teacher at explaining things in a way that you personally understand. When people learn out of their own self interest, that's when you get smart ppl for real that change society and do the big developmental steps. Attachments: DumbingUsDownTaylorGatto.jpg (85.11 KB)
>I'm sorry, but do you realize how insane this sounds? You have no idea if it's hallucinating or not, you're just going based off of vibes on a subject you're not well-versed in, in a situation where there is absolutely reason to assume that risk. If I have doubts I consult the literature, because I pre-read it instead of letting the AI take control, I can always catch a mistake. I've never had the problem where I ended up learning a hallucination. >Studying is inherently an inefficient process, and is intentionally so because we are inefficient beings and the repetition is needed to solidify concepts in our heads. Repetition is exactly what I'm doing when I use flashcards, so I don't see your point. >If you wanted to "solve" studying a decade ago you could have just refused to learn the subject and decided that it was ok with you if the subject could only be recalled by consulting the pre-existing literature. I'm not trying to solve studying, I just want my studying to be more efficient, that's completely different. |
