software is deliberately being designed terribly in order to destroy us
Sep 8 at 01:26:29 in General Discussion | [RSS Feed]
I'm sure you could lower the GDP of a country by introducing specially crafted bugs into their supply chain. Here's an example. I want to copy some text from my browser and paste it into conversations. I copy the text. I app switch back to conversations. At first, the software keyboard is open. Then after about a half second, the keyboard closes. This is already causing a time delay. Now I can either paste into the input box at the bottom or tap it to open the keyboard up again. It's faster to do it while it's at the bottom.
This inherently wastes my time and contributes to stress. The time that I was forced to waste could've been used to find my long-sought-after wife, but nope. It's also about the cumulative effect of a ton of little bugs like this. It's more the cumulative effect than any single bug. One issue is fine, two is acceptable, but three, four.. Eight? Software is deliberately being designed to waste our time and kill us through lack of quality assurance. I'm being honest, it gets me thinking about new concepts. Like how the CIA could try to cause people to have a psychological collapse or to push them over the edge and commit acts of violence through extremely bad user experience.
If you didn't use GrapheneOS, you wouldn't have this problem, though I'm sure there's a way to disable that pop-up. Also this is just one of the limitations of using a touchscreen technology instead of utilizing buttons, it's not software designed against you, it's just the inefficiency of the touchscreen.
I think the CIA has more effective methods than introducing annoying bugs in your software. Especially if we're talking about reducing the birth rate. You just poison the men with xenoestrogens in the food supply, and subsidize female education.
>You just poison the men with xenoestrogens in the food supply, and subsidize female education. What in gods name is a "xenoestrogen"? That sounds unnatural.
Estrogen that is exogenous to the body.
> What in gods name is a "xenoestrogen"? That sounds unnatural. Molecules that have the same effect on the body as natural estrogen, despite being something else. Plastic is a xenoestrogen, and unfortunately it's everywhere. If you drink from a plastic bottle, or you spend a lot of time touching plastic surfaces, you probably have xenostrogens in your body. It's especially harmful for babies and children, as it can interfere with their normal development. The effects on adults are less severe, but still pretty bad: lower testosterone, slower metabolism, depression, infertility...
Yes, for sure. Estrogen from sources outside the body are indeed too common in many products. That being said, I do not really think plastic is simply a form of estrogen and little else; other elements are at play in the composition of it. On top of that, too much testosterone, like too much estrogen, in both men and women, brings about its own set of problems as well. |
