fuck the web, embrace the internet
Even a dual core pentium is a supercomputer by 80s standards, that's THE way to look at it
  • insert one(1) hdd and use as a backup target (you should have multiple, so it doesn't matter if this one fails eventually)
  • fuck the web, embrace the internet: FTP, SMTP, NNTP, IRC and so on, all work without requiring many resources
  • you can host a mail server with ipv6 right from your living room. Pro tip: sending mail is difficult, but receiving mails on mythrowaway@homeserver.funny doesn't require any precautions)
  • set up FTP (with explicit encryption, so FTPES) and never need a cloud drive service again)
  • run several screen sessions with IRC (irssi), torrent (rtorrent seeding Linux .isos)
  • register for one or more pubnix servers (tildeverse.org), run a script with cron that checks for interesting new stuff on them, show in your MOTD which servers have updates so you don't have to check them manually
  • install newsboat and check all your RSS feeds
  • install a newsreader and help revive USENET with a free account from literally anywhere
i feel like nntp is more centralized than http can ever be because you have to >register your account with a >provider in order to even begin using the fucking thing to begin with afaik
I like the list, can you post more ideas?
tell me more about tildeverse why hasn't there been much activity with it since 23?
bump for interests, please respond with more ideas anons
is it worth using smb if i'm too lazy to setup ftpes
Anything is better than dealing with HTTP.
fair enough, i already have smb setup
I've been dabbling with gopher and Gemini last months, I think I'll transfer my websites to there and just ditch HTTP for once, the internet was not meant to be a surveillance protocol
[FR] [DATACENTER]
if you dislike HTTP you probably don't understand it (not even a little bit), read RFC 9110 (and maybe also RFC 9112)
Omg old good new bad very nuanced take this site is so subversive and cool
Replies: >>4523
>>4511
>>4514
>>4517
torposters showing overt contempt for the in-group?
being broad, hostile, and moralizing?
blanket insults aimed at everyone here, signalling non-belonging more than sincerity?
Do not feed the 4channers and their future replies on this site. They'll go home after hours of getting no bites.
I once used gemini and liked it a lot, there's no accounts and everyone is anonymous becaus there isn't anything similar to javascript that can track userd
Replies: >>10187
[PT]
post more ideas anons
[CH] [TOR]
the wiggly wagger walked down to the wiggly wigger to wig the wiggly chigger
[NL] [DATACENTER]
>>10044
isn't gemini read only?
Replies: >>10191
[GE]
>>10187
https://geminiprotocol.net/docs/faq.gmi
1.7 So it's just links to static content, no interactivity?
Well, no. Gemini pages can provide visitors with a written prompt and ask them to type in some text to use as input. This is basically there to make search engines possible, because you need to have some way to enter your search terms. Even Gopher had support for search term input, before Google existed!
But there's nothing special about search engines and search terms, so it's really just a mechanism for pages to get a little bit of user input. People can, and have, used them as a way to let their readers leave comments, sign guestbooks, and that sort of thing.
Gemini even has a way for readers to voluntarily start (and end, whenever they want) a "session", so that applications can maintain server-side state. If you know what CGI apps from the early days of the web are, well, most CGI apps which work with text can be replicated to some extent with Gemini.
Replies: >>10259
[UY]
i support this
what IRC clients do the cyberix users recommend?
Replies: >>10206 >>10351
>>10204
I personally use Konversation if I have to use IRC. It's simple to use and actively developed for. It's KDE's client so that may be a turnoff for some if they don't like KDE or Qt. If you don't mind a client that's no longer updated Hexchat is still viable. If you prefer text-based clients WeeChat and Irssi are still developed for as far as I'm aware of. The only other client I see get talked about and is actively developed is Halloy.
Replies: >>10219 >>10285
>>10206
Halloy hogs memory like a Discord client.
>>10191
the gemini protocol prompts are annoying because they're limitted to single line input. but many gemini capsules and browsers also support the titan protocol for file upload and larger prompts.
are there any cool matrix communities?
>>10206
quassel is also nice
Why would you want a client that is still updated? Doesn't that mean that it isn't finished?
[AT]
