The Cyberix Network The sophisticated man's creative playground. Boards | Connect | Donate | Webchat | [Mobile] 70 connected | Manage
WinClassic's Windows Modding Delusion: Why You Can't Polish a Turd
wirefaux >30d ago #p393 >>quote
A Sisyphean Task
Scroll through any Windows theming community and you'll find the same tragic pattern: hundreds of users desperately trying to make Windows 10 and 11 look and behave like Windows 7, Vista, or XP. They've created an entire ecosystem of hacks, patches, and third-party tools to fight against the very operating system they're choosing to run.
It's digital Stockholm syndrome. They hate what Microsoft has done to Windows, but instead of leaving, they've dedicated their lives to playing dress-up with an increasingly hostile system.
The hack stack
Look at what it actually takes to make Windows 10/11 resemble Windows 7:
  • Mountains of Windhawk mods - Aerexplorer, for example, has to hook into svchost.exe to capture Explorer windows and edit them in realtime.
  • Classic/Open Shell - replaces the Start menu
  • 7+ Taskbar Tweaker - modifies taskbar behavior
  • StartAllBack - another Start menu replacement
  • OldNewExplorer - modifies shell32.dll resources
  • Custom UAC replacements - because even the security dialogs need theming
  • Icon pack replacements - because every single system icon offends them
  • Registry hacks - to dig up and re-enable legacy Windows code or prevent the system from "correcting" their modifications
  • System file patches - that break the moment Windows Update runs or they accidentally type in "sfc /scannow"
>Very stable sir! Ignore the flickering opaque "Aero" glass taskbar sir! This is the real Windows 7, sir! Do not point out the bugs, sir! You are responsible for any and all computer damages, sir!
Each of these tools runs constantly in the background, consuming RAM and CPU cycles to fight against the default behavior of the operating system. The result? A system that uses more resources than either the original Windows 11 or actual Windows 7 would use alone.
The instability tax
This isn't just about aesthetics - it's about fundamental system reliability. Every one of these modifications introduces potential failure points:
Windows Update conflicts: Microsoft regularly breaks third-party modifications, forcing users to choose between "security" updates and their customizations.
Antivirus interference: Security software flags system modifications as potential threats, because that's exactly what they are. Are users of these Windows mods really checking what they're putting inside of their computer? Of course not. This is a massive hack waiting to happen.
Game anti-cheat problems: Modern AAA games refuse to run on "modified" systems, treating your Windows 7 cosplay as potential cheating tools. Just stop playing modern garbage. Problem solved, right? No, there's more.
SFC scan destruction: Running sfc /scannow once will obliterate your carefully crafted modifications, forcing you to start over. Good luck when Windows does its thing and magically corrupts a critical system file that requires you to run that command in order for you to boot.
You're not just running Windows - you're running Windows plus a dozen poorly-integrated hacks that all compete for system resources and stability.
>Oh, just don't restore your computer, don't sfc /scannow, whatever!
The problem with authenticity
Here's the fundamental issue these communities refuse to acknowledge: you will never successfully replicate Windows 7 on Windows 11. The underlying architecture is completely different.
Take the GINA interface from Windows XP. Modders create elaborate workarounds to fake the XP login screen, but they can't actually recreate GINA because it doesn't exist in modern Windows. You're putting a Windows XP costume on Windows Vista's completely different authentication system (plus whenever PINs were added to that system).
The same applies to Aero Glass effects. No amount of third-party transparency effects will recreate the actual GPU-accelerated composition that made Windows 7's Aero work. You're getting a visual approximation that consumes more resources while looking worse than the original.
The ironic solution
The most absurd part? These same modding communities have already proven they can create better software than Microsoft.
They've built:
  • Complete Start menu replacements
  • Custom file explorers
  • Alternative system dialogs
  • Replacement taskbars
  • Custom login screens
If they can write all these programs to work around Windows' limitations, why not just... write them for a better operating system?
The security theater
When confronted with this obvious solution, the modding community always retreats to the same excuse: "We don't want to use insecure OSes that have no software support!"
This argument falls apart immediately:
Windows Vista and 7 still receive security updates for core functionality. Microsoft backported TLS 1.2, SHA256 signing, and other modern security features to Vista SP2. You can run Firefox 141 and compile Java 21 for Vista with minimal modifications.
Software compatibility is largely artificial. The difference between Windows 10 and 11 is smaller than the difference between Vista and 7. Most "Windows 11 exclusive" requirements are marketing decisions, not technical limitations.
You're already running custom software. If you trust random modders to patch your system files, why not trust them to write software for older systems?
The version upgrade treadmill
Consider the absurdity of Windows version history:
Windows Vista introduced the modern Windows architecture. Windows 7 was Vista with a different taskbar and minor kernel improvements. Most Windows 7 features were backported to Vista within months of 7's release.
Windows 10 and 11 both run NT 10.0. They're more similar to each other than Vista and 7 ever were. The main differences are cosmetic changes and minor scheduling improvements that don't affect software compatibility.
So why the obsession with upgrading? If you don't like Windows 11, stay on 10. If you don't like 10, stay on 7. If you don't like 7, stay on Vista. You're not missing any critical functionality by staying put.
The real alternative
Instead of spending hundreds of hours learning to hack Windows 11 into submission, that same energy could be spent:
  • Learning Linux desktop environments that are actually customizable by design
  • Contributing to Wine/Proton to improve Windows software compatibility on Linux
  • Supporting software developers who create light-weight, cross-platform alternatives
  • Building the skills to write your own replacement programs
The tools exist. The communities exist. The only thing preventing Windows modders from escaping Microsoft's ecosystem is their own attachment to the familiar pain of fighting with Windows.
The Cognitive Dissonance
The Windows modding community represents a unique form of technological cognitive dissonance. They simultaneously:
  • Hate how modern Windows looks and behaves
  • Acknowledge that older versions were better
  • Possess the technical skills to create alternatives
  • Choose to waste those skills fighting against Microsoft instead of replacing Microsoft
It's like spending years learning to paint racing stripes on a broken-down car instead of just buying a working vehicle.
The Path Forward
If you truly want the Windows 7 experience, the solution is simple: run Windows 7. If you need modern software compatibility, contribute to making older systems support modern software instead of making modern systems pretend to be older ones.
If you want customization and control over your computing environment, use an operating system designed for customization instead of one designed to fight your every attempt to modify it.
The Windows modding community has already proven they can build better interfaces than Microsoft. They just need to stop building them on Microsoft's foundation.
Stop trying to polish a turd. Build something better instead.
Your energy is finite. Spend it creating solutions, not fighting symptoms.
Replies: >>18918
Tech Stuff >30d ago #p424 >>quote
I will point out that many of the issues mentioned here either are already solved or are being worked on. We've got full hardware accelerated Aero Glass now, thanks to OpenGlass (and previously Glass8), with none of that flickering WindowBlinds nonsense needed. We have in-memory patches that work fine through Windows Updates and sfc /scannow, don't get flagged by antiviruses, and can easily be excluded from games. Most of the performance issues are solved, as almost everything is just tiny in-memory tweaks to the existing code, not massive separate applications.
kawapure >30d ago #p444 >>quote
The most that I'm aware of is downgrading the UI to the more lightweight older version from earlier versions of Windows 10 (I think this has some advantages with classic theme and such). I'm not aware of any proper "custom" replacements. I guess you can do some eyecandy things with Windhawk to make it look a bit more like Windows 7.
Anonymous >30d ago #p472 >>quote
better than all of this, why don't you just use linux and be happy.
Anonymous >30d ago #p604 >>quote
indeed, these windows modders could've wasted their time ricing Linux instead of trying to dodge microsoft aids-ridden buttsecks
Anonymous >30d ago #p640 >>quote
This text is written in the same way ChatLGBT vomits out it's bullshit. Admin should implement a LLM stylometric detection solution and hide these posts. Otherwise months from now, when the site gets real attention, we'll be flooded with posts like this from bad actors and feds.
Anonymous >30d ago #p645 >>quote
AHHHHHHH 9TH GRADE ENGLISH CLASS IS SCARY AND EM DASHES ARE THE BANE OF MY EXISTENCE-I CAN'T HELP BUT THINK OF AI WHENEVER I SEE AN EM DASH OR A PROPERLY FORMED PARAGRAPH AHHHHHHH
Anonymous >30d ago #p1172 >>quote
Awfully defensive there, anon. Are you sure this isn't AI-slop?
Anonymous >30d ago #p1173 >>quote
It's too hyperspecific to be AI slop. AI would've generalized everything, broadened the topic and probably would've refused to write it because anything older than the current thing is "insecure and outdated".
Anonymous >30d ago #p1175 >>quote
The ultimate WinClassic experience is on Linux and, as usual, made by one guy on his free time. https://github.com/rozniak/xfce-winxp-tc
Anonymous >30d ago #p1176 >>quote
>#51996
Might consider installing XFCE for the first time in months, then. I always avoided XFCE because it felt too bloated for me (Maybe battery life on Linux just fucking sucks. Desktop FTW?), but the guy made Silver and the Classic theme so I guess it wouldn't hurt to try and see how it runs
Anonymous >30d ago #p1780 >>quote
Somewhat related rant, see also https://cy-x.net/articles?id=11 Crossposted from lambda
I don't know how people can tolerate Windows 10 (I assume Windows 11 to be similar, although I haven't used it). Even ignoring all the privacy violations, the UI (Windows' selling point, historically) is dogshit, and terribly slow. Right-clicking in the explorer takes several seconds to display a menu. Right-clicking on a file name doesn't even open the correct context menu, you need to select it first (so two clicks). Opening a submenu, then moving the cursor diagonally to the n-th entry closes the submenu. I teach high-school students and these are things that trip them up daily.
Windows 10 on a recent desktop computer is less responsive than Windows 7 in a VM using half a core on a laptop.
Anonymous >30d ago #p1788 >>quote
hello shitgpt, fuck off retard, you are so fucking illiterate you cant write ur own shit then u pass it off as "human"??? FUCK you man XD the chatgptism writing style is still apparent if i wanted chatgpts opinion... ohhh, there it is, chatgpt's right over there
Anonymous >30d ago #p1789 >>quote
>>52731 >t. zoomie is so mindbroken to the point where writing that isn't their tiktok emoji niggerbabble is now ai
Anonymous >30d ago #p1790 >>quote
Shut the fuck up. An article criticizing people for wasting energy on unproductive tasks has spawned a thread where people waste energy arguing whether it's AI-generated instead of engaging with whether Windows modding is actually a productive use of time.
Replies: >>18223
Anonymous >30d ago #p18223 >>quote
>>1790
Because we're not reading a fucking AI slop. If you're here then you should know for yourself the pathetic state of current internet discourse. Or perhaps you don't care, so I'm sure you should go fuck yourself. I aint reading no bullshit, neither should anyone wasting their time on generated text, whether it is "corrected by human" or not.
Using Windows is not a productive use of time. It's like standing butt naked, waiting for another dick from "Satya Nutella" brown faggot to be inserted. And downloading someone else's closed source hacks to patch the retarded behaviour of closed source operating system is the same. You acknowledge the inferiority of contemporary software and instead of doing something to change how YOU are using YOUR computer you just slap "da old lookz" and pretend that you're not cucked. Either way, if you're doing that (or even using closed source operating systems in the first place), you deserve everything you have, get cucked you fucking nigger.
You should shut up. If you really into eating shit go register on character.ai and start talking to your "waifus" you retarded braindead lobotomized moronic utter piece of crap.
You have no right to be here. Logoff and never come back.
Replies: >>18831
pheeaal >30d ago #p18234 >>quote
There is more
https://github.com/aeroshell-desktop/aerothemeplasma
https://github.com/grassmunk/Chicago95
Anonymous >30d ago [US-TX] #p18831 >>quote
[AutoMod] action=keep R:10 E:2 N:1 C:1 | The post is a direct, albeit aggressive, reaction to the preceding context. It fits the thread's tone well.
>>18223
lmao what is this crybaby ass response hahahahah
Anonymous >30d ago [MY] #p18918 >>quote
[AutoMod] action=queue R:2 E:2 N:1 C:1 | The post is pure, low-effort noise with no substance. It is an incoherent string of keyboard mashing that adds nothing to the thread.
>>393
VVVGHHH frvtiger aero kkkino comfy SOVL!!!!!
nayarei >30d ago #p18919 >>quote
[AutoMod] action=keep R:10 E:10 N:9 C:1 | The post is a direct, provocative response within the context of a highly charged, established thread. It fits the established, aggressive tone perfectly.
>heckin fruitnigger areola
The nigger uses the computer as a fashion accessory.
The White man uses the computer to create.
The goyim are niggers.
